kub6040
I have a 46 b and want to put c-146 from a
international 424 in it , is this possible ,
super B ! If not what will fit I want Clydesdale's
not ponies
I think a 135 will fit with some mods.Just take that 113(?) and build it for power. Or get creative and put something really exotic in it!
How many ponies do you want when done as there are ways get a bunch with bolt-on stuff. Money is always the bottom as just how much do you want to spend. Would 45HP from a 135 be close.
I have GMC rv with a 400 cu in it for free. You would have to take the entire RV, it is located in Indiana.
Well I have the 146 . Tried it and 3 of the 6 bolts fit 1 is where the starter was on 424 and the 2on top of the bellhousing are just over the top of bellhousing ,could they be drilled ?
Are you intending to pull with it, or just for looks? If intending to pull, etc. remember the rest of the power train was designed for 20hp. coming off the clutch to quick will result in a lot of repairs. also the B engien was the structural center of the tractor, you will have to build rails for a non tractor engine.
