1086 Brakes
After talking to you guys here I am going to put new o-rings in my brake piston assembly
I have read the manual and it dosent sound very hard am I missing anything
Also the manual calls for a type of loctite gasket maker is that something special or can I use permatex gasket maker instead
I figure I will check the pads while I am in there too
Thanks fof any advice
It needs to be an anaerobic gasket eliminator sealer. Permatex 51813 will work instead of the Loctite number.
