tractordanp
Follow up on 560 with Swartz front pulling I finally got time to look into your suggestions here's what I have found
Toe in right to spec , tires all seated correctly wheel bearings seem really good no drag as I can tell , brakes not dragging , tire pressures match from side to side , but while checking rear pressures I noticed right tire has a third more fluid than left side and left side tire I would say 40% and right side 20 to 25% thread so thinking between the two that's my pull I think.
I waiting to run it across scales to check my weight that way I can deside weather to add more to one or less to other to hit weight class for pulling shooting for 8300 hopefully this week we get thawed out enough at work to turn scales on.
Thanks for your input and please feel free to tell me if I am way off base with my thoughts it does happen just ask the ol lady
Dan
