986 3 point problem
when i raise my 3 point it wont lift all the way. it lifts about half way and thats it.. would a bad filter cause this?
Check the linkage at the lower end of the control lever under the cab. It is slotted & can come loose. Also normal wear in the lever pivot & linkage can cause it. Slot will help compensate for some wear.
