Vincents454
New User
When the IPTO lever is engaged, there is no pressure to the PTO clutch. No fluid comes out of the fitting when the lever is off, but when the lever is engaged fluid comes out with no pressure. I have removed the mcv and made sure all he passengers are clean. The power steering works correctly, the three point hitch lifts and lowers as it should, and the aux hydraulics strain the engine when you engage the lever. I don't think there is pressure to the IPTO valve. I think it is working correctly, it moves up and down the correct amount and allows fluid when engaged. Just no pressure. If the power steering is working, where is the pressure going?
