farmall 400 pto wont turn under a load
krob
In a hurry, auction starts in an hour,good running 400 w/after market wf and ps. fast hitch 3 remotes good rubber. Needs ta rebuilt and the pto slips under a load. Whats it worth and how much too fix the pto. I have a good idea on the ta and it is a luxury that i can live without for a little while. Thanks
I would say it is worth $1500-$2000.
It may be as simple as needing the PTO bands adjusted. Worse case scenario the one band would need to be replaced. I have heard of people swapping the bands around as the band on the brake is usually worn a lot less than the power band.
New bands are $600 each, but you can buy a complete PTO assembly at a salvage yard for a LOT less than that. You could even take the bands to a clutch & brake shop and have them relined.
