Block configurations
Checking to see if anyone knows how many C-153 block configurations there are? I have one from a 2504. It is different than the one I have from a combine. The flywheel end on the 2504 has a different bolt pattern. I presume front is different as well for WF to bolt up? Thanks
(quoted from post at 20:33:05 03/27/14) Checking to see if anyone knows how many C-153 block configurations there are? I have one from a 2504. It is different than the one I have from a combine. The flywheel end on the 2504 has a different bolt pattern. I presume front is different as well for WF to bolt up? Thanks
391239R21 - 3514 tractors
375597R31 - (2)504 tractors
405163R92 - Combines and swathers
388575R31 - (2)444 tractors
Owen,
Thanks for the info! I have another engine number that you may know or not? 356318-R1. I believe it is a C-123 but the block isn't marked.
Thanks Mike
