Rustyone
Is there an easy way to get the thermostat out of the housing on a 281 motor? thing is stuck in the casting,(broke off a utility knife blade in it)! Any tricks. Thanks, Rusty
utility knife is wrong tool. use screwdriver or something you can get in there with. cant be that stuck. if all fails then you could unbolt the housing from head and give it a smack from that direction with something that works.
