1 pt. disc harrow
Ron130
New User
Found a 2 gang disc for my Farmall 130 with 1 point fast hitch. Can anyone tell me the model? See the photo; it's just like the red one.
Need help adjusting it; when I lower the disc the front gang outer blades are floating just on the surface.
Sorry. Couldn't get the photo uploaded before
It's like the red disc in the foreground.
(quoted from post at 23:02:35 03/22/14) Sorry. Couldn't get the photo uploaded before
Try adjusting the hydraulic lever for the depth. That should do it.
Do you have the piece that connects the front, (right side)hydraulic arm to the front of the drawbar, under the floor pan? you need that to level the rear implement front to back. I have a 100 single point hitch, have a harrow , need to use the front hydraulic operated arm to make it work. If you have a single point plow, you need that same arm to get the plow to dig in.
Thanks for the suggestions. I will try lowering the bail and connecting to the right side hydraulics as I would for my hillside plow.
Again.Thanks1
That would be a 1-F36 disk harrow. You will need the draft control rod that goes from the front of the fast hitch bail to the right hand rock shaft of the touch control. That will allow you to level the disk front to back. The draft control rod is essential to use any ground engaging implements with the one point hitch. I have the exact same disk harrow as yours. Recently acquired. The F1I-1 parts catalog shows several one point implements, including your disk. It's 496 pages, so not cheap. Reprint is available from binder books.
