TractorLinks.com
Show Parts for Model:
Re: 300 Utility Hydraulic Pump
SALTY
03-02-2014 08:30:31
Where would you put the second pump? How do I determine if the priority valve is dumping?
Janicholson
03-02-2014 08:41:15
 Re: 300 Utility Hydraulic Pump in reply to SALTY, 03-02-2014 08:30:31
The second pump is often placed to the under side of the generator, or above it. The pump can be from medium duty commercial trucks (from salvage) or from automotive applications that have remote reservoirs. (easiest to position and plumb. Driven from a belt, and hooked exclusively to the PS unit, it allows the original (I assume working) hydraulic system to operate as designed.
The system on your tractor is neither easy to understand, nor easily modified outside of factory components and intentions. Best of luck, I cannot give more info on why what you have done is not working. Jim
