TractorLinks.com
Show Parts for Model:
Re: Farmall 450
tom dowling
03-01-2014 07:39:49
Milky oil? Do you keep the tractor outside? I thought I had a blown gasket or cracked head/block also, turned out it was rain water going in the seams of the muffler and around the threads of the pipe at the manifold. A flapper or can on the muffler isn't good enough. Loosen the oil drain plug a bit and see if you are getting green or clear water. If it's green your outa luck, if it's clear then it's rain water and you can change the oil, run tractor till warmed up and change it again. Then let it sit there and run an hour or so to steam out any remaining water. It worked good for me.
