Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 364 heating
JimB2
03-01-2014 05:39:27
Hi, yes, stuck thermostat can cause over heating.
Depending on the age of your BD-154 there should be a thermostat bypass.
First I would check that the new head gasket is not leaking into the coolant. When engine is cold, remove rad cap and start engine and let it run until it is warmed up and observe coolant through rad filler watching for air bubbles. Also coolant level should be just above the rad core when cold and 1/2 inch or so below the bottom of filler when warm. After engine warms up and thermostat opens you should be see the hot coolant circulating on the top of the rad.
If you have access to an infrared heat gun, you can check engine block, top to bottom rad temps.
Top should be hot, bottom cool.
Other things to check are:
1)Bottom rad hose for collapsing
2)Clogged rad cores, all the hot coolant stays at the top
3)Air flow through rad
4)Stuck thermostat, can removed and replaced
Caseih.com parts:
3042303R92 is a replacement part for the obsolete part(s) 369322R91, 180F degree thermostat.
I cannot recall if BD-154 uses a standard automotive thermostat or not.
Hope this helps
JimB
ironhorsedriver
03-02-2014 09:15:27
 Re: 364 heating in reply to JimB2, 03-01-2014 05:39:27
Hey Jim, I think the radiator is bad. Do you know who carries them? I've checked all my online parts dealers, Case/IH even says they don't have them. I know they are EXPENSIVE.
ironhorsedriver
03-01-2014 06:00:54
Thanks Jim, It looks like a standard auto type thermostat.
