Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: wd9 problems
Red Mercury
02-28-2014 21:22:08
I agree that it sounds like something is not letting the starting valves close or all 4 are damaged (not likely).
Instead of using the starter to "test" diesel side compression you can also use the hand crank if you have one. Definitely harder to roll the engine over with the crank when it is on the diesel side. With the crank you can easily tell if the starting valves are closing, resulting in good compression on each cylinder.
Copyright © 1997-2015 Yesterday's Tractor Co.
