1086 lift adjustment
gbs
we just rebuilt an open center lift on a 1086 it works good except for the drop speed,from full raised to full lower it works fine,problem is when I try to lower it small amounts it drops to fast,also what is the proper adjustment for the action control valve, manual skipped over that part,does it affect drop speed when using the the position control lever
I just went and pulled out my service manual GSS-1470-3 w/revision 3 for the 86 series tractor and there are 10 pages of instructions for checking and adjusting the open center hitch system. My e-mail is open. Charlie U
thanks for the reply charlieu,that's the manual I have but for some reason it doesn't cover the adjustment of the action control valve spring tension,don't know if that is causing the problem i'm having or not
