Would a slightly bent clutch disk cause the clutch pedal to be hard to push?
After Dad had the DT360 bus engine installed in the 756, you had to be Jahunga the Enormous to push the clutch pedal.
Dad had to split it recently to address an oil leak, and he found the clutch disk was bent!
All he replaced was the clutch disk, but now the pedal pushes easy, like it did back when it had a gas engine in it.
