dewy
Need to know the proper procedure on how to get a precise setup on the front cultivators? They were folded for transport, got both sides unstuck and mounted. Now need to know, if the handles on the springs are what you adjust to pick it up and down.
Thanks Dewy
Don't give up on us, just put a clear topic in the subject line. (I know nothing about 200 cultivators) They lift for travel in the field with the hydraulics on every tractor with hydraulics. The lever adjustments are usually for individual shovel depth to avoid covering crop, or to adjust shovel to shovel width.
There may be more than one model, so a picture will help dramatically.
Jim
No. There should be a rod from the rock shaft on the cultivator frame to the front hydraulic rock shaft. I will try to show a picture or two.
reason i asked such a stupid question.. was because ithought it woulg be self explanatory..right side would put down pressure but not lift it.. hooked up left side an tryed it and snapped the rock shaft right off of tractor ......my rock shafts on both sides are different than any i ever seen ... mine wher e pointing down with one ,looks like pigs ear... ever other rockshaft looks like a spade with two holes.... and pointing up...went to salvage yard replaced with spade type and cultivators are working right now....what did i have will try pics to day dieing to know....thanks to all dewy
