Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Speaking of 56 series shifting...
mkirsch
02-28-2014 07:12:31
65.199.189.6
Would a slightly bent clutch disk cause the clutch pedal to be hard to push?
After Dad had the DT360 bus engine installed in the 756, you had to be Jahunga the Enormous to push the clutch pedal.
Dad had to split it recently to address an oil leak, and he found the clutch disk was bent!
All he replaced was the clutch disk, but now the pedal pushes easy, like it did back when it had a gas engine in it.
[Reply]   [No Email]
mkirsch
02-28-2014 11:54:58
65.199.189.6
 Re: Speaking of 56 series shifting... in reply to mkirsch, 02-28-2014 07:12:31
No hydraulic assist on the clutch.
When we put the tractor back together this time, it fell together EASY.
The time before, they had a heckofa time getting it back together, and that's probably when the clutch plate got bent.
[Reply]  [No Email]
MN Scott
02-28-2014 22:08:42
184.158.53.204
 Re: Speaking of 56 series shifting... in reply to mkirsch, 02-28-2014 11:54:58
On the 06,56,66,86 series tractors I always put the pressure plate and disk on the trans input shaft first, the join the tractor then reach up from the access hole on the bottom and bolt the pressure plate to the flywheel. No chance of bending things that way.
[Reply]  [No Email]
Janicholson
02-28-2014 13:54:27
199.17.6.78
Was there some possible binding in the linkage, or T/O bearing misalignment that would cause overpressure?
Binding would seem to be the only reasonable cause.
Unless the PP was changed and it had different spring rates in the coils. Jim
[Reply]  [No Email]
Janicholson
02-28-2014 10:22:32
199.17.6.25
The only thing that I can relate to the issue is the adjustment of the clutch assist system (if it has one) that uses MCV pressure. A bent disk only makes the travel to full release longer, and engagement some what softer. Difficult shifting might also be a result if it drags when fully depressed. Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
