Which spark plugs for C-123 engine?
djhammerd
I have a 51 or 52 Super A with a C-123 engine (replacement for C-113). The tractor does not get heavy use, and may sit for significant time between startups. I have read that it may be better to use "hotter" spark plugs than the factory recommended spark plugs.
What spark plugs (brand and number) should I consider putting in this tractor?
Thanks in advance...
(quoted from post at 07:15:30 02/21/14) I have a 51 or 52 Super A with a C-123 engine (replacement for C-113). The tractor does not get heavy use, and may sit for significant time between startups. I have read that it may be better to use "hotter" spark plugs than the factory recommended spark plugs.
Autolite 386, or the hotter 388, OR if you still have the magneto ignition, use the non-resistor Autolite 3116.
i believe that champion plugs do not rust as quick as some of the others.
i would use a hotter spark plug than what is recommended
I think my Super C has Champion D21 in it, don't have any problem with them, haven't had them out in 6 or 8 years.
