TractorLinks.com
Show Parts for Model:
Re: Super A Starting Problems
C. Amick
02-20-2014 09:26:49
I"m not advocating that you should convert it to a 12 volt system. Most of my tractors are still 6 volt and work fine. Just make sure you have the larger battery cables for the 6 volt system. I think the minimum cable size is #1. You can still jump start it from a 12 volt system without damage to the 6 volt system, if you hook the jumper cables at the starter. Hook one to the starter post and the other to the tractor body. No, you don"t have to change to a negative ground. Just make sure the switch is on. :)
