TractorLinks.com
Show Parts for Model:
Re: Ring and pinion questions
D Slater
02-19-2014 18:49:08
If the 560 is early with a 3 bolt rear main shaft bearing housing, all you need to do is use the W-400 R&P and the W main shaft rear bearing housing. If its a 4 bolt bearing housing you may need to make a spacer along with the shims to get the gear contact right. If wanting ground speed changes. Need to look up all gear ratios in the transmission and rear end. Also the tire size and at what engine RPM. Bunch of figuring for both sides of the T/A and 5 gear speeds.
