Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Super A Starting Problems
djhammerd
02-19-2014 15:23:55
Just came back in from hooking up the throttle line to the governor and setting the throttle (at the driver lever) to about half speed.
The tractor still didn't start. I used a little starter fluid directly into the opening of the carb again.... and choked a bit also.
It did fire once... Only once.
I also put the inline spark detector on a couple plugs again. There definitely is spark, but again it looks weak. When I tried that earlier and didn't see the bulb light, there must have been too much daylite.
This post was edited by djhammerd at 15:25:46 02/19/14 2 times.
Janicholson
02-19-2014 16:48:11
 Re: Super A Starting Problems in reply to djhammerd, 02-19-2014 15:23:55
Did you clean and gap the points? Did you pull the plugs and heat them with a propane torch then reinstall? Did you try putting WD40 (a 1/2 second spritz) in each hole before putting the warm plugs back in? Did you try pull starting it? Jim
djhammerd
02-19-2014 17:22:51
 Re: Super A Starting Problems in reply to Janicholson, 02-19-2014 16:48:11
Janicholson said: (quoted from post at 17:48:11 02/19/14) Did you clean and gap the points? Did you pull the plugs and heat them with a propane torch then reinstall? Did you try putting WD40 (a 1/2 second spritz) in each hole before putting the warm plugs back in? Did you try pull starting it? Jim
I did clean and gap the points. I can try warming the plugs and using WD40 tomorrow.
I can't really pull the tractor until the snow is gone and it dries up a bit (maybe next week). That will tell me if faster turning-over will help.
All good ideas. Thanks!
I think I may move the ground cable over to a bolt on the starter also, just to be more direct for the troubleshooting.
This post was edited by djhammerd at 17:25:04 02/19/14.
