Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall C Steering Gear Box - Oil Level
leon
02-19-2014 04:01:12
I got real lucky. Had the steering box apart on my SC, put it back together with new seals, etc., nothing special, just the way it was supposed to be, put in the recommended oil and it hasn't leaked a drop in several years. Maybe my converting it from tricycle to wide front helped, but it's nice to have one that doesn't leak. Both my JD H and MT leak, even after having the MT apart and going back together the same way I did on the IH SC. As soon as it stops leaking, indicating all the oil is out of it, I'm going to refill it with JD corn picker-head grease. I hear that dries 'em up. That's what I put in my AC G last fall, and no signs of leaks - of course even hell's froze up this winter.
sparky70
02-19-2014 06:49:15
 Re: Farmall C Steering Gear Box - Oil Level in reply to leon, 02-19-2014 04:01:12
Ouch! I just had my super c front end apart and installed new seals but no grease. Have not drove it yet cause I have to boil gas tank, but sure hope it does not leak. Did not even think about grease
Gerry Powell
02-19-2014 20:19:42
 Re: Farmall C Steering Gear Box - Oil Level in reply to sparky70, 02-19-2014 06:49:15
A good solution which I did on my SA is to remove the fill plug and then drill and tap and install a grease fitting. When you lube the tractor, give it one squirt.
Jim Becker
02-19-2014 07:11:19
Quoting Removed, click Modern View to seeIn that case, oil should stay in it.
Copyright © 1997-2015 Yesterday's Tractor Co.
