Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
M Farmall Transmission noise
Scott Glick
02-18-2014 18:08:00
173.184.83.144
Just recently aquired a 52 M Farmall. It has noise in neutral and reverse only. Where do I start?
[Reply]   [No Email]
John M
02-19-2014 03:03:08
209.213.28.157
 Re: M Farmall Transmission noise in reply to Scott Glick, 02-18-2014 18:08:00
Is the clunk consistent, or just like random clunking? Mine would do like clunk, clunk, quiet, clunk, quiet, quiet, etc. No set pattern to it. The reverse whine, well, I don't think Ive ever heard any manual transmission that didn't have some whine in reverse, but is this a new thing its doing?
[Reply]  [No Email]
Allan In NE
02-18-2014 21:09:48
199.47.66.62
PTO shut off? They set up a whine if it's engaged.
Allan
[Reply]  [No Email]
Scott Glick
02-18-2014 19:13:36
173.184.83.144
Its a whinning noise in Rev. a clnk noise in neutral
[Reply]  [No Email]
Janicholson
02-18-2014 19:36:31
74.60.94.18
 Re: M Farmall Transmission noise in reply to Scott Glick, 02-18-2014 19:13:36
The reverse whine is in my oopinion, normal. the neutral noise could be several things, including the drive coupling in the torque tube, the front shaft bearing, the constant mesh gear, or the intermediate bearing. Jim
[Reply]  [No Email]
D Slater
02-18-2014 18:34:45
184.14.194.242
Just a wild guess that maybe the main shaft bearing that pilots into the input shaft is just starting to go bad. In neutral the main shaft is not turning and in reverse the main shaft turns opposite of the input shaft. In the other gears the main shaft turns the same direction as the input shaft but at different speeds unless in 5th. maybe turning the same direction is enough to not hear the noise if the bearing isn't completely damaged.
[Reply]  [No Email]
Janicholson
02-18-2014 18:21:41
74.60.94.18
Noise in Neutral can be from a variey od sources. The most important info is what the noise sound like.
Fromt input shaft bearings, Intermediate (pilot shaft) bearing, Counter shaft bearings, and the constant mesh gears are all in motion. When in forward gears (except 5th) there is pressure on the gears/bearings that might cause less noise. reverse is inhearently more noisy than the others as it has an idler to go through as well. Give us a sound. Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
