TractorLinks.com
Show Parts for Model:
Re: Farmall C Steering Gear Box - Oil Level
Stemmy
02-18-2014 17:29:54
more than likely its the drain plug. drain it and fill the gearbox with some good tacky grease. that way you dont have to worry about it making a mess if it ever leaks.
C. Amick
02-18-2014 18:55:34
 Re: Farmall C Steering Gear Box - Oil Level in reply to Stemmy, 02-18-2014 17:29:54
I have used a 50/50 mix of gear oil and grease on others that leaked. This one is not leaking, but I may take your advice and go with a heavier than gear oil mixture.
Rick Remmert
02-19-2014 17:34:01
 Re: Farmall C Steering Gear Box - Oil Level in reply to C. Amick, 02-18-2014 18:55:34
I would agree with a 50/50 mix. That is what I put in mine last winter while I had it apart. I went all summer and has not leaked yet. Also, as many have said on here before, corn head grease would probably work also.
Stemmy
02-18-2014 18:58:30
man you're lucky, all mine were leaky. My H was the worst.
leon
02-19-2014 04:01:12
 Re: Farmall C Steering Gear Box - Oil Level in reply to Stemmy, 02-18-2014 18:58:30
I got real lucky. Had the steering box apart on my SC, put it back together with new seals, etc., nothing special, just the way it was supposed to be, put in the recommended oil and it hasn't leaked a drop in several years. Maybe my converting it from tricycle to wide front helped, but it's nice to have one that doesn't leak. Both my JD H and MT leak, even after having the MT apart and going back together the same way I did on the IH SC. As soon as it stops leaking, indicating all the oil is out of it, I'm going to refill it with JD corn picker-head grease. I hear that dries 'em up. That's what I put in my AC G last fall, and no signs of leaks - of course even hell's froze up this winter.
sparky70
02-19-2014 06:49:15
 Re: Farmall C Steering Gear Box - Oil Level in reply to leon, 02-19-2014 04:01:12
Ouch! I just had my super c front end apart and installed new seals but no grease. Have not drove it yet cause I have to boil gas tank, but sure hope it does not leak. Did not even think about grease
Gerry Powell
02-19-2014 20:19:42
 Re: Farmall C Steering Gear Box - Oil Level in reply to sparky70, 02-19-2014 06:49:15
A good solution which I did on my SA is to remove the fill plug and then drill and tap and install a grease fitting. When you lube the tractor, give it one squirt.
Jim Becker
02-19-2014 07:11:19
Quoting Removed, click Modern View to seeIn that case, oil should stay in it.
C. Amick
02-18-2014 19:02:42
Could be that it's not leaking because there may not be any oil in it? :)
