farmall a thrust plate
buggsy
so my thrust plate is wore out , 1/4 inch end play
since these are not easy to come by i was going to get the machine shop to make one, what would the best material be
thanks
1. Original part # is 43249D. If you GOOGLE "IH 43249D", you"ll find there"s all sorts of NOS ones out there.
2. The new part number is 374704R1, and it APPEARS to be available, but just over a hundred bucks.
3. If the plate is worn a lot, how much is worn off of the front face of the cam or the back of the timing gear?
well i undone the plate and it is perfect shape it seems that the gear is not on as far as it should be, taking it to machine shop to get it pressed on to where it is supposed to be
I was wondering about that, but your previous post made it sound like the plate was worn!
I am glad the link helped you ,just about everything 1940&newer is there (except my orchards 04s & o6s of coarse)not a lot of them to make it worth there time , it is a lot of info , stumper
