TractorLinks.com
Show Parts for Model:
Re: Farmall H carb
D Slater
02-18-2014 10:08:42
Think that's where a passage was drilled in the carburetor and then plugged on the outside. Plug should stay there. If just one side of the idle jet ears made for a screwdriver to fit is broke it will work okay if the hole in it is open. Around a .022 or .023 hole. If broke off even with the casting it needs replaced. About the flutter, do you have a magneto or distributor ignition? Notice Pete already gave you a answer while I was typing.
This post was edited by D Slater at 10:14:31 02/18/14.
martin h
02-18-2014 10:27:16
 Re: Farmall H carb in reply to D Slater, 02-18-2014 10:08:42
Thanks for some of the explanation. I have a magneto on my tractor. Ya i was going to check the timing and make sure everything is lubricated and working well.
