Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Farmall H carb
pete 23
02-18-2014 09:58:28
That brass part you have circled is a plug. Not a service item as it is used to plug one of the internal passages during the manufacturing of the carburetor. When you say sputtering, I guess you mean it spits and sputters when you go from low engine speed to high speed. What we term as cold blooded. Pretty hard to cure completely and if you did the engine would probably run pretty rich after it got up to speed. Far as idle jet, the actual jet is quite a ways down inside of the long jet so if the screwdriver slot is damaged it most likely still does not affect the jet. Broke a few off in my day. Have a tap to restore threads as needed. Also, never heard of a good rebuild kit for an H. I always buy the parts I want separately. Lot are no longer available.
martin h
02-18-2014 10:26:11
 Re: Farmall H carb in reply to pete 23, 02-18-2014 09:58:28
Thanks for the info and for answering my questions. Ill play around with it later. The idle metering jet isn't broken, just the screwdriver tabs and the hole appears to be clear. Thanks again
