Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
656 Hydro
504
02-17-2014 19:24:03
199.127.54.155
The shifter will jump out of it s slot if you pull it all the way into fast reverse. I have looked at everything I can find and I don t see any kind of stops or pins to keep it from moving too far. It is the valve on the bottom of the shifter that falls out.
[Reply]   [No Email]
pete 23
02-18-2014 10:04:48
74.33.78.170
 Re: 656 Hydro in reply to 504, 02-17-2014 19:24:03
There is no stop other than the end of the slot in quadrant. How is the neutral adjustment. Lever should move same amount in forward as reverse to start movement of tractor. Often times the whole quadrant gets loose , cracked or broken corners off lower mount so it does not limit lever properly.
[Reply]  [No Email]
504
02-18-2014 18:10:39
199.127.54.155
 Re: 656 Hydro in reply to pete 23, 02-18-2014 10:04:48
Neutral is right where it should be, maybe the cowl is not setting right? I can reach in with a flat bar, move the piston in and slide the shifter back, till I forget and pull it in to reverse too fast and then do it again.(PIB)
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
