574 range lever
Brass Ring
New User
have 1968 IHC 574 with range shifter shaft broken off in tranny wall. stuck in reverse. what is best way to access and remove to replace broken shaft?
You have to do from the top..remove fuel tank, seat, tin that seat is mounted to and hyd lines etc...Then remove top cover of tranny. Its heavy so a hoist is needed. A five minute job once you get all the stuff out of the way..Just had to do the same thing to a 674...part was around 80 bucks
Hi Brass Ring,
From archives:
Broken Shifter Lever:
Hi Irving, I have changed many of those parts, at
the Case-IH dealer, where I have worked for. You
can remove the lever and replace it by the left
side of the rear transmission. Just drain the oil,
remove the MCV control valve ( the plate that hold
the hydraulic pump and filter) With a short 7/8
open wrench, loosen the sealed nut, remove the
broken shaft and replace with the new one. It has
a big spline for the timing. Just align the short
lever with the fork.
Bernard le mécano Québec Canada
Hope this helps
JimB
