What Keeps The Cranckshaft pulley on a '47 Farmall Cub
KCTractors
Location
Central Wi
Have a guy over-hauling the engine on a Cub and he asked what keeps the crank-shaft pulley on the crank, he said there was no nut or anything on it. I looked at him kind of dumb, and said, the heck if I know. So what does keep it on?
(quoted from post at 23:56:17 02/01/14) Have a guy over-hauling the engine on a Cub and he asked what keeps the crank-shaft pulley on the crank, he said there was no nut or anything on it. I looked at him kind of dumb, and said, the heck if I know. So what does keep it on?
If he has to ask, he might not be the one you want to have overhauling it. :roll:
"When finished, do you put it back on with a big hammer?"
You can if you want to damage the main bearings...
To reinstall properly, the end of the crank is threaded with 1/2-20 threads. Install a good length threaded rod and line up the pulley with the keyway. Use a plate with a hole for the threaded rod and pull the pulley on with a nut. Use anti-sieze on the crank and the threaded rod, along with a couple grease covered washers behind the nut to act as a thrust bearing. Some people heat the pulley up before installation, but its not necessary.
