cub hydraulic leak?
ericlb
my 49 cub had developed a new leak, it apears to be comming from the bottom of the touch control housing where it meets with the tractor itself, its been a few years since i put a kit in that but i dont remember anyplace on the bottom of that where it could leak,it seems to be comming from between the 2 pieces, the tractor and the touch control housing, not the gasket or plate that is about a half inch up from there, it runs down both sides of the touque tube any ideas before i pull the hood off and the control unit off?
I have an F Cub and it did the same thing. When I took it off it was coming from around the pistons and running back thru the boot and out along the base of the unit
