Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall M Starter Problems
gene bender
01-20-2014 02:18:14
Not uncommon with newrings both of your starters are probably needing to be refreshed. You know the engine is free because you turned the engine over somehow when you installed the new rings. You could pull the tractor to get it started and get it running after a good warm-up then your starter mite work. Is the battery up to snuff and are the cables and the sw up to snuff. I find the same problem sometimes after a new engine is finished. You also could use a 12v batt to start. You know the engine is free cause it does turn oever just not fast enough to start.
farmallguy1923
01-22-2014 10:00:52
 Re: Farmall M Starter Problems in reply to gene bender, 01-20-2014 02:18:14
I have already started it multiple times. There is probably around 5 hours on the new rings. I am having to crank start it right now. It has a new six volt battery and new wires.
