300 Flow regulator question
I removed the fuel tank and replaced the O-rings on the plugs in the flow valve today. One question, I did not notice when I took the spring and outside cap out that the cap had two slots cut in it. I replaced the cap with the slots lined up with the hydraulic line openings in the valve. I hope this is correct?
Danged if I know for sure what you mean. If it is the slots in the cap with the o-ring behind the snap ring, it makes no difference what so ever.
The slots went inside the valve and the O-ring was on the outside. These slots were inside where the pin in the cap holds the spring centered.
