Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: engine rebuild - basket case- need advise
notjustair
01-19-2014 08:50:35
If it were me I would pull the caps, crank, and pistons. Clean the block good just like you would for a rebuild. Clean everything like you are doing a rebuild and lube it. Blow out crank passages and reassemble. Basically do it just like a rebuild without putting in new parts. That gives you the opportunity to plasiguage things and verify the work.
You never know how much junk is in the assembly lube. There's no need to have it dipped as far as I am concerned, just do a meticulous clean and check the clearances on things. Cleaning it good also let's you check for cracks.
300dave
01-19-2014 09:25:07
 Re: engine rebuild - basket case- need advise in reply to notjustair, 01-19-2014 08:50:35
OK no pulling sleeves and dipping OK
How much air pressure to clean passages?
El Toro
01-19-2014 19:02:25
 Re: engine rebuild - basket case- need advise in reply to 300dave, 01-19-2014 09:25:07
If you remove any pipe plugs make sure you reinstall them. Hal
Janicholson
01-19-2014 11:24:54
Air guns have pressure restrictor ports to prevent blowing air into skin. The pressure is about 25psi or so. that will do just fine. Jim
Janicholson
01-19-2014 09:03:14
I agree. Just no reason not to. A few hours redundant work not might save a full rebuild one houre after a startup. Cheap insurance. No gaskets have been used so far, no loss. Jim
300dave
01-19-2014 09:26:23
 Re: engine rebuild - basket case- need advise in reply to Janicholson, 01-19-2014 09:03:14
OK as above, gasket is there, but the mice got in, head gasket is very rusty ha ha i hate those guys
