Yesterday's Tractor Co. Compare our Prices For Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
engine rebuild - basket case- need advise
300dave
01-19-2014 08:28:35
74.32.160.145
I would like to get some opinions from you guys on how to proceed with this one.
Recently bought at estate sale is 1-C175 engine out of a 350 utility machine. The machine went off for scrape. The engine is mounted in a engine stand.
It is half way through a complete rebuild: that is
Crankshaft tuned and over sized bearings installed.
Rods installed with sleeves and pistons and rings ( all new). It sat this way for several years. There is light flaky rust on all the outside block surfaces. The inside off the block looks OK. Slight rust in the cylinder tops, but not pitted, rubs off.
Also, rust in cam follower slots, etc. Gears for cam and crank have surface rust. I pulled cam shaft and it has surface rust on lobes, very minor; more of a stain, no pits.
Crankshaft and pistons turn fine. Head is here and has been redone; greased and wrapped in plastic, new valves. Looks OK. Have all other parts in boxes.
So, question is, where to go now. ??
How can I be sure that NO rust particles get in the oil and bearings? Would magnets in the oil pan work? Should I pull the sleeves and crank and have the block hot dipped?
What is best way to be sure no rust chips get in and bind up the crank shaft?
Especially down in those oil passages I cant see into.
Any help here greatly appreciated.
tx in advance
dave
[Reply]   [No Email]
gene bender
01-19-2014 10:08:28
207.177.56.213
 Re: engine rebuild - basket case- need advise in reply to 300dave, 01-19-2014 08:28:35
Nice to hear you say oversize bearings cause they would be over when the crank is ground.
[Reply]  [No Email]
Bob
01-19-2014 10:25:53
64.255.159.192
 Re: engine rebuild - basket case- need advise in reply to gene bender, 01-19-2014 10:08:28
Actually, UNDERSIZED would be the correct term.
Link to ASE opinion on that...
http://www.freeasestudyguides.com/crankshaft-bearing-inspection.html
[Reply]  [No Email]
notjustair
01-19-2014 08:50:35
174.250.179.191
If it were me I would pull the caps, crank, and pistons. Clean the block good just like you would for a rebuild. Clean everything like you are doing a rebuild and lube it. Blow out crank passages and reassemble. Basically do it just like a rebuild without putting in new parts. That gives you the opportunity to plasiguage things and verify the work.
You never know how much junk is in the assembly lube. There's no need to have it dipped as far as I am concerned, just do a meticulous clean and check the clearances on things. Cleaning it good also let's you check for cracks.
[Reply]  [No Email]
300dave
01-19-2014 09:25:07
74.32.160.145
 Re: engine rebuild - basket case- need advise in reply to notjustair, 01-19-2014 08:50:35
OK no pulling sleeves and dipping OK
How much air pressure to clean passages?
[Reply]  [No Email]
El Toro
01-19-2014 19:02:25
96.244.7.206
 Re: engine rebuild - basket case- need advise in reply to 300dave, 01-19-2014 09:25:07
If you remove any pipe plugs make sure you reinstall them. Hal
[Reply]  [No Email]
Janicholson
01-19-2014 11:24:54
74.60.94.18
Air guns have pressure restrictor ports to prevent blowing air into skin. The pressure is about 25psi or so. that will do just fine. Jim
[Reply]  [No Email]
Janicholson
01-19-2014 09:03:14
74.60.94.18
I agree. Just no reason not to. A few hours redundant work not might save a full rebuild one houre after a startup. Cheap insurance. No gaskets have been used so far, no loss. Jim
[Reply]  [No Email]
300dave
01-19-2014 09:26:23
74.32.160.145
 Re: engine rebuild - basket case- need advise in reply to Janicholson, 01-19-2014 09:03:14
OK as above, gasket is there, but the mice got in, head gasket is very rusty ha ha i hate those guys
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
