Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: IH 460 gas blowing black smoke
K.Barry
01-18-2014 18:39:56
when you say air cleaner you mean the part with the oil cup.... no sir I did not clean any of that out. how often should this be done...also my choke cable is broken so I manually do it at the carb and it stays where I put it and when I unchoke it it stays in the unchoke position. mu and water?
Janicholson
01-18-2014 18:51:39
 Re: IH 460 gas blowing black smoke in reply to K.Barry, 01-18-2014 18:39:56
Mud is what old meant in his reply. The service interval on oil bath air cleaners is dependent on conditions ranging from twice daily, to twice yearly. Very dusty or high pollen weed disking can plug up the filter easily in a day. The normal interval on non dusty work might be a month if used 5 hours a week. So it needs it. (use engine oil and after cleaning fill to the groove on the cup.
The high speed mixture might be a little rich (that was the High concept mentioned as well) see the manual for adjustment. Jim
K.Barry
01-18-2014 18:56:36
 Re: IH 460 gas blowing black smoke in reply to Janicholson, 01-18-2014 18:51:39
ok thanks a lot this helps.....hopefully also the pto is busted of right at the housing and all I need in my opion is the shaft correct? I know there were sevral ptos on the 460s and 560 I have a little plug or vent cap right in the center top do you know what type this would be?
old
01-18-2014 19:00:55
 Re: IH 460 gas blowing black smoke in reply to K.Barry, 01-18-2014 18:56:36
I learned years ago to open it up then figure out what parts you need. A broken PTO shaft can cause many other things to go bad so it you open it up then order parts your better off then to order parts then open it up. And yes it should have read MUD not MU but spell checker did not catch that LOL
Copyright © 1997-2015 Yesterday's Tractor Co.
