TractorLinks.com
Show Parts for Model:
Re: Water in castings while tractor is in shed (pics)
Allan In NE
01-18-2014 18:16:17
What!
Are you trying to tell us that you don't keep your tractors in a heated, humidity controlled environment? :>)
Allan
Dan Nelson
01-18-2014 18:32:51
 Re: Water in castings while tractor is in shed (pics) in reply to Allan In NE, 01-18-2014 18:16:17
Humidity in a building is probably higher than outside especially when the weather is warming. So you get lots of condensation on the outer surface of things like castings. Condensation on the inside of say a gearbox depends on how much moisture is in the air inside. There will be some for sure but not as much as in the air outside. Loosen the drain plug around springtime, keeping threads engaged, watch for water dripping out. Retighten the plug.Water will be at the bottom of the oil. Run the tractor AFTER doing this. Dan
Janicholson
01-19-2014 07:50:26
 Re: Water in castings while tractor is in shed (pics) in reply to Dan Nelson, 01-18-2014 18:32:51
Just to let you know, Allan in NE is speaking with toung firmly being chewed. Jim
