Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Water in castings while tractor is in shed (pics)
sflem849
01-18-2014 17:50:12
69.197.84.39
I know there are some that say tractors only get water in the rearend from sitting outside. I would have to say these pictures tell a different story. This was last week. Tractor hasn't moved in 4 months. Temps were -20 for a couple days and then it "warmed up." Temps were still at or near freezing. In my opinion, if there is that much water on the outside of the casting there is just as much on the inside.
[URL=http://s1246.photobucket.com/user/sflem849/media/SMTA/IMG_20140111_093055025_zpsjzmwadk8.jpg.html][/URL]
[URL=http://s1246.photobucket.com/user/sflem849/media/SMTA/IMG_20140111_093221464_zpstfssqoy4.jpg.html][/URL]
[Reply]   [No Email]
gene bender
01-19-2014 13:09:35
207.177.56.213
 Re: Water in castings while tractor is in shed (pics) in reply to sflem849, 01-18-2014 17:50:12
So where is the outside damp air getting into the tranny i havent seen any holes for the air to get in the tranny.
[Reply]  [No Email]
sflem849
01-19-2014 14:31:39
69.197.84.39
 Re: Water in castings while tractor is in shed (pics) in reply to gene bender, 01-19-2014 13:09:35
Gear shift is a 2" hole. That's a good start. Vent on Hyd tank. Vented gas cap. There are plenty of openings all over the place.
[Reply]  [No Email]
gene bender
01-21-2014 06:01:58
207.177.56.213
 Re: Water in castings while tractor is in shed (pics) in reply to sflem849, 01-19-2014 14:31:39
the shift lever is on top of the tranny and spring loaded thats the only opening in the tranny you would need pressure or sit out in rain for a long time to get and water in the tranny and you said yours is inside. I have the original B my Dad got for me new in 47 and it still doesent have any water in the tranny as i changed it just for fun cause the B will get a good cleaning.
[Reply]  [No Email]
Owen Aaland
01-19-2014 07:17:04
216.47.34.47
The air inside the housings is constantly being exchanged. Not only due to changes in temperature, which changes the air density, but any change in barometric pressure moves air in or out of the housing.
[Reply]  [No Email]
old
01-18-2014 18:26:20
209.86.226.54
Yep condensation get every where no matter what and you can not stop it you just have to be sure you check things or you end up with a machine that will not move when you need it due to ice some place
[Reply]  [No Email]
Allan In NE
01-18-2014 18:16:17
199.47.66.59
What!
Are you trying to tell us that you don't keep your tractors in a heated, humidity controlled environment? :>)
Allan
[Reply]  [No Email]
Dan Nelson
01-18-2014 18:32:51
38.108.87.20
 Re: Water in castings while tractor is in shed (pics) in reply to Allan In NE, 01-18-2014 18:16:17
Humidity in a building is probably higher than outside especially when the weather is warming. So you get lots of condensation on the outer surface of things like castings. Condensation on the inside of say a gearbox depends on how much moisture is in the air inside. There will be some for sure but not as much as in the air outside. Loosen the drain plug around springtime, keeping threads engaged, watch for water dripping out. Retighten the plug.Water will be at the bottom of the oil. Run the tractor AFTER doing this. Dan
[Reply]  [No Email]
Janicholson
01-19-2014 07:50:26
74.60.94.18
 Re: Water in castings while tractor is in shed (pics) in reply to Dan Nelson, 01-18-2014 18:32:51
Just to let you know, Allan in NE is speaking with toung firmly being chewed. Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
