TractorLinks.com
Show Parts for Model:
Re: Farmall h weak spark
El Toro
01-18-2014 16:32:09
Your coil or the mag's magnets may be getting weak causing the weak spark. I would first check the magnets by touching them with a flat blade screwdriver. They should attract the screwdriver with a good bit of effort. If they have strong magnetism I would replace the coil. Be sure to check your point gap should be .013" also clean the points with some 320 wet or dry until shiny. Hal
Brady miller
01-18-2014 17:12:06
 Re: Farmall h weak spark in reply to El Toro, 01-18-2014 16:32:09
Is the magnet the cylindrical piece going through the coil or the sides where the coil screws to? I haven't worked on mags much.
If someone could briefly explain or point me to a video or something on how the mag works. Thanks
teddy52food
01-19-2014 08:08:30
 Re: Farmall h weak spark in reply to Brady miller, 01-18-2014 17:12:06
The magnet is on the shaft running through the mag. The impulse driving it is on one end. The mag has to be disassembled to get it out. If you take it out, get 2 curved pieces of iron on each side to act as a keeper or it may lose some strength.
Janicholson
01-18-2014 16:44:49
See my comment on the original post. Do you have the picture of the external coil converted mag? Jim
Brady Miller
01-18-2014 17:40:45
 Re: Farmall h weak spark in reply to Janicholson, 01-18-2014 16:44:49
Jim,
No I do not have that picture. can you send me one?
Janicholson
01-19-2014 08:59:46
 Re: Farmall h weak spark in reply to Brady Miller, 01-18-2014 17:40:45
Please find the picture above in El Toro's response to me near the current top of page.
The ballast resistor (grey diagonal item) is not needed as yours is 6v, his was 12v with a 6v coil. Jim
Janicholson
01-18-2014 18:43:44
It is El Toro"s Picture. I found one of the examples of where it was posted here, but it is "moved". Lets hope El Toro reads this and reinserts it into parts and Pieces or somewhere to look at it. THe image shows the mag with a coil and wiring mounted to the outside. (the image also shows a ballast resistor which you would not need). Jim
