Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Int'l 504 Brakes
mkirsch
01-18-2014 16:27:05
They're real simple to work on. Unscrew the pedal linkage from the front. Remove 5 (or 6?) bolts from the drum. Remove the drum. Everything else hangs on the pinion shaft under the drum. Brake disk, actuator, brake disk.
If the brakes are just weak, all it probably needs is just a good cleaning and new disks. IMHO, no lube period, but some people recommend a little graphite on the balls.
504
01-18-2014 19:24:53
 Re: Int'l 504 Brakes in reply to mkirsch, 01-18-2014 16:27:05
I had one side hanging up on my 504 Farmall. I was sure I would find a bad grease seal, I was happy to see nothing more than rusty ramps and one worn out disc. It is back together, but the test run will be in March(when it is warmer)
Copyright © 1997-2015 Yesterday's Tractor Co.
