Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Farmall h weak spark
Brady miller
01-18-2014 15:54:52
166.137.156.35
Gents,
I showed my dad the spark on the mag and we think it's weak and it seems to miss a spark ever once in a while.
All gaps are good timing good everything spot on. What about replacement parts?
[Reply]   [No Email]
El Toro
01-19-2014 08:41:18
96.244.7.206
 Re: Farmall h weak spark in reply to Brady miller, 01-18-2014 15:54:52
Here's a picture of a H4 mag converted to a distributor. You use the points in the mag and disconnect the coil wire from mag's points. Battery voltage needs to be run to an ignition switch, to an auto type coil and to the points in the mag. If you're still using the 6 volt battery with positive ground you run the hot wire to + terminal on the coil and a wire from the neg
terminal on the coil to your points. Hal
[Reply]  [No Email]
El Toro
01-20-2014 07:29:09
96.244.7.206
 Re: Farmall h weak spark in reply to El Toro, 01-19-2014 08:41:18
I told you the wrong way to wire your auto type coil if you decide to install one. If your battery is 6 volt and has the + terminal grounded your + terminal on the coil is wired to your points. Hal
[Reply]  [No Email]
teddy52food
01-18-2014 16:49:28
184.94.175.179
Check your E-Mail.
[Reply]  [No Email]
El Toro
01-18-2014 16:32:09
96.244.7.206
Your coil or the mag's magnets may be getting weak causing the weak spark. I would first check the magnets by touching them with a flat blade screwdriver. They should attract the screwdriver with a good bit of effort. If they have strong magnetism I would replace the coil. Be sure to check your point gap should be .013" also clean the points with some 320 wet or dry until shiny. Hal
[Reply]  [No Email]
Brady miller
01-18-2014 17:12:06
166.137.156.42
 Re: Farmall h weak spark in reply to El Toro, 01-18-2014 16:32:09
Is the magnet the cylindrical piece going through the coil or the sides where the coil screws to? I haven't worked on mags much.
If someone could briefly explain or point me to a video or something on how the mag works. Thanks
[Reply]  [No Email]
teddy52food
01-19-2014 08:08:30
184.94.175.179
 Re: Farmall h weak spark in reply to Brady miller, 01-18-2014 17:12:06
The magnet is on the shaft running through the mag. The impulse driving it is on one end. The mag has to be disassembled to get it out. If you take it out, get 2 curved pieces of iron on each side to act as a keeper or it may lose some strength.
[Reply]  [No Email]
Janicholson
01-18-2014 16:44:49
74.60.94.18
See my comment on the original post. Do you have the picture of the external coil converted mag? Jim
[Reply]  [No Email]
Brady Miller
01-18-2014 17:40:45
107.196.147.229
 Re: Farmall h weak spark in reply to Janicholson, 01-18-2014 16:44:49
Jim,
No I do not have that picture. can you send me one?
[Reply]  [No Email]
Janicholson
01-19-2014 08:59:46
74.60.94.18
 Re: Farmall h weak spark in reply to Brady Miller, 01-18-2014 17:40:45
Please find the picture above in El Toro's response to me near the current top of page.
The ballast resistor (grey diagonal item) is not needed as yours is 6v, his was 12v with a 6v coil. Jim
[Reply]  [No Email]
Janicholson
01-18-2014 18:43:44
74.60.94.18
It is El Toro"s Picture. I found one of the examples of where it was posted here, but it is "moved". Lets hope El Toro reads this and reinserts it into parts and Pieces or somewhere to look at it. THe image shows the mag with a coil and wiring mounted to the outside. (the image also shows a ballast resistor which you would not need). Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
