Yesterday's Tractor Co. Tractor Parts for All Brands
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Int'l 504 Brakes
steamship
01-18-2014 14:34:19
67.241.173.188
My dad has had his 1963 International 504 since the early 1970's. He'd like to rebuild the brakes for the first time since he's had it (they are very weak) and I'm going to help. Neither one of us has had these type of disc brakes apart before. We've looked at quite a few drawings, but that's no substitute for experience. Would you fellas mind letting me know what to look out for and what parts typically have to be replaced? Disc linings for sure, but maybe the balls, springs, steel plates, links, plates, etc? Thanks for the help.
[Reply]   [No Email]
steamship
01-19-2014 17:59:51
199.120.189.2
 Re: Int'l 504 Brakes in reply to steamship, 01-18-2014 14:34:19
Thanks for the guidance guys. Doesn't sound bad at all. I was expecting the worst, but I'll get prepared with a new set of brake pads and that'll most likely take care of it.
[Reply]  [No Email]
mkirsch
01-18-2014 16:27:05
67.253.175.33
They're real simple to work on. Unscrew the pedal linkage from the front. Remove 5 (or 6?) bolts from the drum. Remove the drum. Everything else hangs on the pinion shaft under the drum. Brake disk, actuator, brake disk.
If the brakes are just weak, all it probably needs is just a good cleaning and new disks. IMHO, no lube period, but some people recommend a little graphite on the balls.
[Reply]  [No Email]
504
01-18-2014 19:24:53
199.127.54.155
 Re: Int'l 504 Brakes in reply to mkirsch, 01-18-2014 16:27:05
I had one side hanging up on my 504 Farmall. I was sure I would find a bad grease seal, I was happy to see nothing more than rusty ramps and one worn out disc. It is back together, but the test run will be in March(when it is warmer)
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
