How in the world do you replace on 300?????
The pressure regulator flow control valve plug on the inside of the valve block is leaking. Before I do all the painting on it, how in the devil do you replace a 1.25 O-ring. The main line from the pump comes in there and elbows right in front of this plug. If I take out the outside plug and spring, the plug could be removed easily, but there is very little room to remove the snap ring and the plug!!!!!!!!!!
Not simple. I would just remove the fuel tank and then take the whole regulator valve assembly off, or you could probably get the line off , take elbow out after tank if off.
