TractorLinks.com
Show Parts for Model:
Re: MD won't stay running on gas
old
12-25-2013 17:51:28
Do not know the MD well but know to old TD-6 which works the same way. Sounds like the carb is running out of fuel. If the carb has a drain plug which I think it should have pull that plug and let the fuel flow for a few minutes. I'll almost bet the flow slows down so when it slows down the engine dies due to lack of fuel Moist likely a float set wrong or a sticking float needle
Janicholson
12-25-2013 18:36:56
 Re: MD won't stay running on gas in reply to old, 12-25-2013 17:51:28
I agree (past MD owner) the flow into the carb is pretty substantial. It needs fuel. They run rich, it should flow a 1/8" stream for 60 seconds into a clean can. If not the lines, strainers, and sediment bowl to tank passage need to be clean. Jim
