taking old tire off rim
ephhs
Which side of the rim does the tire come off the easier? I am going to take the back tires off a cub tractor. I can not tell any difference in the rim width on the valve side or the back side. Will the tire come off easier on one side or the other?
On tractor rims it does not matter what side but since I did tires for a living for a while I pretty much always pull them off the stem side to make it easier to remove the tubes and also easier to put the tube back in to get the tube stem on the hole if fits in
If the rim is loose,go from the stem side.If the rim is still on the tractor,dismount right on the tractor.It wont matter then.
