Pictures needed.
J. Schwiebert
I need some pictures for an article I am doing some research on. I need a picture of the fuel system on a WD-40, a MD with a BOSCH injection pump and an early International diesel with the IH fuel pump. In fact if any of those requests would be on engines in crawlers that would be fine as well as a 6 cylinder engine or crawler with the IH pump would be great. Thanks in advance. Merry Christmas! J.
I googled "bosch injection pump picture" and I got two pictures. On one the pump is in a vise and the other it was on a motor.
here is the pump on my 1939 wd40.
got some of the gas side also. the first wd40's came out with the injectors under the valve cover on top of the head. then they went to the 10 degree head and then as mine is the 45 degree head.
would you want a picture of a 45 degree head 40 series diesel with an IH filed changeover conversion to a single plunger A model pump?
Don't know how fast you need them I can get you pics of a bosch system in a 41 td6 and am currently working on a 41 md with bosch injection. Jim.
Thanks to all of you that responded to this. I will e-mail you and explain where the pictures are going. You will probably laugh. Thanks again. J.
