TractorLinks.com
Show Parts for Model:
Re: F20 speed
Old-F20
12-18-2013 20:54:42
The Heisler setup is the ONLY aftermarket gear box that will directly affect your internal transmission gears. all the other 'over drives' are just that, and over drive. you have ot have your main transmission in neutral to use them so it doesn't matter what 4th gear you have, it wont be used. The Heisler setup acts as a 'step up' type transmission that doubles all 4 existing transmission gears.
mschwartz
12-18-2013 21:30:21
 Re: F20 speed in reply to Old-F20, 12-18-2013 20:54:42
Thanks for the info, Heisler would be the much preferred aftermarket box then. Do you know if the F14 road gears would be the same? I have what I thought was a M&W road gear on my F-14 and it speeds up all three gears, maybe it is a Heisler will have to go look at it closer tomorrow, was on tractor and working when I purchased tractor so have not researched as well as I should have. Thanks again, Mike
