buggsy
hello
i am fixing up my old A and trying to figure out how to get the bearings off the input shaft on the back, i have the front of the shaft all undone but cant seem to figure it out from there
ok i found out how
need to punch out pin holding reverse gear in order to remove shaft and get at the back bearing, all good except broke punch off in hole, drilled pin from other side then broke drill bit , so a whole new world of problems
