TractorLinks.com
Show Parts for Model:
Re: 1951 C wont crank
mkirsch
12-17-2013 11:31:59
Starter is real easy to remove. Less than 5 minutes. Unhook the ground cable to the battery. Disconnect the battery cable from the starter. Undo two bolts. Slide starter out.
When you get the starter out it may be VERY obvious what the problem is.
Once you've done that, try to crank the engine by hand just to see if it is free. If the engine won't crank over by hand (transmission in NEUTRAL) you got big problems. Time to drop the oil pan and pull the valve cover, and possibly the head.
