pulling an injector pump 560d
tbish
my question is whats the procedure for pulling the fuel pump some one told me u had to time it before u pull it off I think its toast not getn any fuel
I had a almost same problem.My 560D would not start and I had just ran it a few days before. I checked and good flow to pump, glow plugs working fine and spinning over good but no smoke.I talked to an old tractor mechanic and he told me sometimes he has seen the pump shut off plunger get stuck.I tapped on pump while had dads spin tractor over and started up, this was about a year ago and still starting up ok.
Procedure for removal is to take off the timing cover on side of pump. Little plate with two screws. Turn engine until the timing mark on governor aligns with stationary mark you see inside. It will only align with number one piston on compression stroke and should be at 3 degree before top dead center on the front pulley. Might be a degree or two off and you may very well have to turn engine two full revolutions because pulley marks will align on number six also but pump will not on that engine.
As long as you are taking it off you may as well pull top cover to make sure metering valve is not stuck or something came unhooked. Also, a rap on the side of the pump with a plastic hammer might just get it going again, never know.
